Drive Shaft question?
Fergy19
castlegar/british columbia
Hi, I've recently had some issues when switching into 4x4 in my truck.. As soon as its locked in and I drive forward/reverse there is a loud clunking sound coming from what I suspect is my driveshaft? I've crawled under the truck (not very hard to do lol) and wiggled the front driveshaft around and it does seem pretty loose but I'm not entirely sure. Any other suggestions?
Stroked68
This is FORD Country
Eudora, KS
Could be the joints on each end of yer front axle. No matter what u join it is, get good ones like moog or some other brand that has grease zerks. I hate non greaseable joints!
f100cleveland
When In Doubt,THROTTLE ON
Southern Minnesota
Did you get longer drive shafts with the lift? You might be over extended on your slip joint and its barely engaged and splines are worn.
