Ecm-TDE0-TDE1-TEE5
94f450sd
certified nutjob
plymouth,ma
My 95 is running tee5 (tee4 forgot wich) my chip was burnt for tde1.I found a tde0 ecm.any reasons to use or not use the tde0? I know the factory programming is better than the tee4/5 but the chip is supposed to override it with the tde1 programming.would I be better off with the tdeo/tde1 combination?
I don't think it matters or at least that's what I've always been led to believe. the programming of the OE computer made a difference with some of the early single page chips and they were written to work with a specific base program and modify specific parameters with the "newer" multi-page chips this problem has been eliminated as the chip overrides the ECM base programming.
castellscl
