Edge Juice/Attitude warning level settings?
jawalt
Bothell, WA
Just installed this in my truck and I really like it. I wanted to check to see what other people are changing the values to for the warning/alarm levels. Main concern to me is the warning level for
Tranny Temp (200 something)
Engine Temp (200 something)
EGT (1350)
Boost (50)
Turbo Timer (EGT 350)
Thanks
James
wheelhopper
southern/MD
I am surprised no one has responded to your post. The tranny temp I am not sure about. As far as the others.
Engine temp I would set a little higher, 210-215. EGT I would drop to around 1200-1250, not worth blowing your turbo unless your getting ready to win $10K. Turbo timer, 350-375 is good.
judd.mcclure
San Antonio, Texas
EGT i would go to 1500, with some of the SPARTAN tunes 1600 can easily be seen when racing. These motors are built to withstand the heat. Not to mention some of my regens when i had a dpf would hit 1325 degrees
TEXJAL0304
MIDLAND TEXAS
i have had the juice with attitude for about a year and a half and i use to run it on 5 all the time. in doing that i burned up 2 egt sensors. i take it off every time it went to the ford house and the warrantied it everytime. i put it back on about a week ago and i am running it no higher than 3. guess we will c if that helps with not burning the egt sensor out.
