FORD F350 1990 7.3 D E4OD TRANS PROBLEM
FURLANETTO 4X4
I AM REPAIRING F350 1990 7.3 D E4OD TRANS
I AM NOT ABLE TO SOLVE A PROBLEM.
THE VEHICLE IN LOW (1) MANUAL AND DRIVE (D) ALWAYS STARTS TO MOVE IN HIGHER SHIFT.
CAN YOU HELP ME, PLEASE.
THANK YOU,
MANUEL
Zookie400
I WANNA GO FAST
wallingford, CT
check the adjustment, make sure its actually in the gear you think it is. if its in "2", it will lock into 2nd instead of first even when stopped.
FURLANETTO 4X4
F350 E4OD PROBLEM
THANK YOU,BUT I HAVE ALREADY CHANGED TRANSMISSION RANGE SENSOR WITHOUT SUCCESS. I TRIED ALSO TO CHANGE VALVE BODY ASSY.
TEXCRAWLER
TEXCRAWLER
B. F. E.
The E4OD is a ticking time bomb. That bites. I went through 3 of them in my 7.3 IDI and then it went up in flames. Don't know if it was electrical or the Mexicans in the hood I pissed off and they get bak at you by screwin w/ur sh!t. I'm sure you know what your doin, but mabey low fluid and is it the correct fluid.
TEXCRAWLER
TEXCRAWLER
B. F. E.
4...108AYsmLJs1auQ
castellscl
