Question fuel pump issue again?
atk
Moderator
simcoe, ontario, canada
well it seems like fuel pump is going south again. was replaced last December.
even when they replaced last year, it seemed a little bit louder then the original, but the truck worked good. i am going try to hook up a fuel pressure guages and see what the psi is, but i am sure it will read low, do to the noise it is making....
just have to figure out why?????
no-red 6 0
Senioritis
southmetro MN
-popcorn-popcorn
alex, are u still running the b20? could that be it - and or- a combination of the additives you are using?
or just plain old bad luck:dizzy:tounge
atk
Moderator
-popcorn-popcorn
yeah i was using anywhere from B5-B20(with additives), depending what time of the year. i am now just using regular ULSD. yeah i am a little hesitant on what i will be putting in my fuel........OR, it could be the bad luck thing....:dunno
on a side note, i have changed the fuel filters regularly and they never seemed too dirty when i did....even Ford couldn`t explain the pump failure....
