gauges?
MUDWHISTLE
Diesel Lover
oregon
wheres the best place to put the trans temp and the boost pressure fitting on a 2004 6.0 I know where to put the pyro but want to make sure that I get the right place for the other two? thanks Lee Pictures would be a great help.
sawed off
Party like a rockstar
EGF MN
your boost should be installed on the intake elbow. I heard if you tee it in like you can do on the 7.3 it may cause gauge flutter. As far as the trans temp, you replace a plug with a sending unit on the bottom of the tranny. Check out www.thedieselmanor.com they have install pics on there as well. Hope this helps! good luck
