Help Needed glowplugs///// Students need help!!!!!
racerx250
NJ right by the GW Bridge & PA
I found a diesel school were the students will do my glow-plugs and gaskets and wire harness... the problem is that some glowplugs swelled up and broke off.... Can the pieces be FISHED -OUT or should they remove the heads....
The instructor is waiting for me ... I told him I think I have seen on a post somewere here that It can be fished ....
Thanks
:dunno
Zookie400
I WANNA GO FAST
wallingford, CT
heads off!
this will be an excellent "real world" learning experience for them. fresh coolant, plugs, gaskets.......the engine will be happy when they are done.
bears4x4
grease monkey
katy texas
couldnt you fish them out through the manifolds, when each cylinder is at the bottom of the compression stroke
No way can you get a tool/wire/grippers into a valve opening and down about 3.5 inches and grab it. Take the head off!!!
