Hellwig Sway Bar - all about the stability of your truck
If you are sick and tired of trying to find a high quality replacement sway bars for your truck, meet a set of solid sway bars made by Hellwig.
Those durable constructions crafted from chrome moly steel, specifically sized and tuned to give your truck advanced stability and
perfect handling characteristics.
Hellwig® - Sway Bar
http://www.carid.com/hellwig/sway-bars.html
* Sets of sway bars are tailored for on-road use;
* Reduces side-to-side body roll around turns, enhances tire grip, and optimizes stability at higher speeds;
* Multiple mounting holes at sway bar ends can be used to vary stiffness level;
* Powder coat finish resists corrosion, chips, and scratches better than paint;
* Includes durable polyurethane bushings that resist deterioration, cracking, and drying out under extreme use;
* Also includes mounting brackets, end links (if applicable), and related hardware;
* Limited lifetime manufacturer warranty;
* Manufactured in the United States;
If any additional questions appear, feel free to contact me, we will be glad to help you out.
Detailed information about the Hellwig manufacturer can be found here: http://www.carid.com/hellwig/
