Hey thats the One... I went with Black... as I will be using mine extensivly... easier to re-pant than to Polish... any way after you remove the bumper to put the braket into the frame,, put your Tow hooks in then, as you will not find enough room to put the bolts in once its mounted, The Bumper gets in the Way.
Also this is a good time to do the Zoodad mod if you havent already, the hole (s) you drill will make routing the 2 Gauge cable easier.. oh and one last thing ... you will have two nuts with wire tac welded to them, on the end of the wire take a pair of pliers and make a small loop, it will help you move and hold that nut in place.
