High Idle Control
Tbar
SDD STAFF/Moderator
I would like to add high idle control to my truck? Is there a way to use the upfitter switches or can I get the option with a tuner?
Tbar
Tbar
Hey T,
Many tuners offer a High Idle, as an option.. I ordered a DP tuner with a 1200rpm high idle.. works well.
dpantazis
#12
under the cheddar curtain
ummmm, why?
do you have need or want? there is a difference.
if i recall correctly, trucks shut off after excessive idle time to protect emissions system.
otherwise....
https://www.fleet.ford.com/truckbbas/non-html/Q180-A.pdf
Sent from my DROID BIONIC using Tapatalk 2
ummmm, why?
otherwise....
Hmmmmm..
Nice when yer caught in traffic for a few.. A/C is cooler.
Nice when yer doing a Jump Start.. speeds up & raises the volt/amp input.
Nice if yer using yer Winch.
Nice when using an Inverter.
' jus to mention a few uses ? :);)
Plus your Link
Tbar
SDD STAFF/Moderator
Yea Joe, I seem to idle a lot. According to the computer I have 1500 miles on the truck and 18 hours idling. Serously considering the tuner with that option as it looks way simpler than rigging the upfitter switches.
Tbar
Yea Joe, I seem to idle a lot. According to the computer I have 1500 miles on the truck and 18 hours idling. Serously considering the tuner with that option as it looks way simpler than rigging the upfitter switches. Tbar
;);tu Had to wait for a KFC drive thru order last week.. 105* out. Parked. Flipped the high idle on.. sat in the coool'r A/C, listen'n to the (((XM.
Life is good.
Don't know if the 6.7 is different from the 6.0 on the upfitter switch's,
but on mine I just wired two wires together. I put mine on number 4.
Good point Doug & Sage. Me & my 2k will be on the Endangered Species list here purdy quick ;).. maybe it's something as simple as what you did.
(OBTW ? I've got an OEM Idle Control module (mounts under the dash), if anyone is interested in one ??? PM me ???)
sagebel
Stock? Pfft!
Albuquerque, NM
Found some pictures:
You can get a knob for the potentiometer from radio shack. I mounted mine next to the 4x4 switch. I'll try to get a pic tomorrow.
Here is the potentiometer
Latest posts
