Holset HX 50
roosterdiesel
Earl needs B100
Amarillo,TX
It's a Holset turbo of an M11 Cummins. Similar in size to the H2e. I'll have to fab a mounting kit if I decide to run this.
platinum01
Willis, TX
I see. Price cheaper? Any bennifits from running this turbo? I understand that it is bigger.
roosterdiesel
Earl needs B100
Amarillo,TX
Cheaper than??
The turbo itself is cheaper but then you have to spend time in fabrication or buy a mounting kit. H2e kits are 2200ish including turbo from most vendors.
Benefits...better boost to back pressure ratio, more air, no surge(but I don't have surge with the ATS housing, more air. Hopefully won't be too laggy.
