How can I make it stop??
atk
Moderator
simcoe, ontario, canada
Is there a place that has them already made so all I have to do is either bolt or weld them on?
Or do I have to fab. my own?
most aftermarket suspension companys have either one. i priced some last week and they range from 200-800 bucks up here....hope this helps some
second option is, to make your own, which i might do.....
Zookie400
I WANNA GO FAST
wallingford, CT
L&L makes a bolt in set. the install is insanely easy, drill a few holes and bolt in a bracket. they work. my only complaint is that they are short, and look silly on a crewcab long bed. fabbing your own would be easy too, just remember to make a shackle at the front of each bar so it can travel front/back with the suspension.
Michael
Gauge Guy
Portland, OR
A "quick and dirty" improvement is to clamp the leaves together in front of the rearend. It helped my wheelhop but did not eliminate it. I found some ready-made spring clamps (squared-off U-bolt with plate) at the local hardware store.
Anyone have a link to the L&L units?
Regards,
Michael Pliska
