Help Needed ICP no power
starduster
Santa Cruz,CA
2005 F-250 6.0 runs very rough has no power like it use to. I have the Edge CTS monitoring system
on there and the ICPv reads 0 and of course with that value the ICPpsi reads 870 (which we know is false). The codes it was reading are 2285,2286,2287. After replacing the ICP and pigtail (yes the new pigtail is wired correctly) I am getting the same codes and 0v at the ICP. I have inspected the harness and all connections to all I could see, so now I am thinking I need to break out the voltage meter and start checking things myself. I am thinking that I should verify the integrity of the main harness. Any suggestions would be greatly appreciated.
bismic1
To help in your troubleshooting ......
FOR 05 and UP - With the ICP connector facing away from you (looking at the back of the connector) and the connector lock tab down:
The wire on top is a sensor monitor or signal wire (dark blue / light green) - goes to PCM connector C1381C (center plug), pin 29
The wire on the left is the signal return to the PCM (grey / red) - goes to PCM connector C1381a (center plug), pin 33
The wire on the right is the 5 volt V-reference power to sensors (brown / white) - goes to PCM connector C1381a (center plug), pin 45
Also as a reference - the ICP connector number is C1244
starduster
Santa Cruz,CA
Thank You, I just now visually inspected the harness for chaffing, other than being a little on the brittle side it appeared to be ok.
I will put my meter on those wires this afternoon, Thanks again.
