Question Injectors????
jerryjust
SDD NEWBIE MEMBER
Baja, BC. Mx
Replaced 8 injectors and one was different then the other.Is that the way they come???
Jerryjust:confused::confused::confused:
Welcome to SDD.. but what year truck ? which engine ?
Tell us about yer truck ?
jerryjust
SDD NEWBIE MEMBER
Baja, BC. Mx
Why new inj!!!!!
Drove to Mulege,Baja Mx. near Cabo and got some bad fuel,had to drain tank and blow out lines.
jerryjust
Tail_Gunner
CRJ & ERJ A&P Mech.
Da U.P.
X2
Sounds like it might be a long lead injector. It was Ford's fix for a problem known as "cackle". It was a problem caused by inadequate fuel getting to the #8 injector. Their brillant fix was to put in a modified injector instead of fixing the problem with the fuel system.
If you are experiencing a "cackle" problem, shimming the FPR may help out some. Making sure you aren't getting any air in the system will also help. The "Hutch" mod takes care of those typical problem point where air gets sucked into the fuel.
jerryjust
SDD NEWBIE MEMBER
Baja, BC. Mx
Injectors!!
Never thought about that,it looked the same but had a different number. You hit the nail on the head. My head. Thank's.
jerryjust:)
jerryjust
SDD NEWBIE MEMBER
Baja, BC. Mx
Big joe!!!
It is a;
2001
Ford
F350
Super Duty
Crewcab
LongBed
4x4 89,000
All Stock. Scared to alter any thing,every thing I read it says don't change anything,it will damage it badly.Since I am retired and on fixed income
I have to take of the last vehicle I will ever own.
Jerryjust:):):)
