Introducing Go Rhino 5" V-Series V3 Black Side Steps
climb-in-your-truck-easy-with-new-go-rhino-v-series-v3-black-side-steps-collage_0.jpg
These new Go Rhino V3 side steps feature an aerodynamic design with a slick modern look. They are expertly manufactured from premium-quality corrosion-resistant aluminum alloy and reinforced with a full-length extruded aluminum core. Durable brackets allow for 300 lbs of load per step or 600 lbs per side in four-door versions of the vehicles. The oval-shaped steps are finished with a textured black powder coating and feature 5-inch wide anti-slip polymer step pads with a multi-dimensional tire tread pattern.
Step pad threads are specifically designed to allow for rain, snow, and slush to drain off easily and reduce the risk of slipping while stepping up into your vehicle. Hardware and mounting brackets are included. The installation process is fairly easy and doesn’t require drilling or other modifications. Go Rhino's V-Series V3 Side Steps offer strength and rugged good looks. Besides, reinforced extruded aluminum cores protect the sides of the vehicle from damage if you happen to travel on rough terrain.
Click the link below to read more:
Climb in Your Truck Easily with New Go Rhino 5" V-Series V3 Black Side Steps
https://www.carid.com/go-rhino/news...ew-go-rhino-v-series-v3-black-side-steps.html
To browse the full catalog of Go Rhino accessories, use the link below:
Give our sales team a call at 800.505.3274 (Toll-Free) or 1.609.642.4700 (International) and we'll answer all your questions.
