kill switch
jlayne
Paint Sniffer
Milledgeville, Ga
not really a "switch" but the most reliable way to choke a diesel is with a intake (air) shut off
it is like a valve that blocks air from the intake and suffocates your engine... most all of the pullers use something like this
this type of engine kill will also protect it from a run away... however unlikely that is
Ford_Forgotton
Im assuming you mean to prevent theft?
Install a switch on the CPS. No Tach signal, no start :D . It will crank, but no start.
Install a switch on the brake wire. If the brake wire is switched, you cant shift the truck out of Park. (auto only). Truck runs, but cant drive.
Install a switch on the starter relay. Truck wont crank.
Tbar
SDD STAFF/Moderator
ForumBlue said:
What is the best way to install a kill switch?
Do you want to kill the engine or prevent it from starting???
Tbar
ForumBlue
CDXX
Southern California
As a matter of fact, let me explain further. With the chip I paln on getting I will have to disable PATS. So I'm looking for a way to keep the truck from starting.
I am extremely open to alternate suggestions.
Thanks.
Jamie
jlayne
Paint Sniffer
Milledgeville, Ga
ForumBlue said:
Sorry, Should have been more detailed. I want to prevent it from starting.
oops i though you was referring to pulling or the drags... daryl's ideas sound like they would fit your application then
ForumBlue
CDXX
Southern California
Daryl,
Is it possible you could PM me or post a "how to" at your convenience of course. I have much confidence that you can lead me in the right direction seeing you got my fog lights hooked up a heck of a lot better that how I planned on doing it.
Thanks.
Jamie
