Locking the converter
HowieE
Princeton NJ
TS Performance Torque Converter Lock-UP
Look at this link, should be what you are looking for ;tu
You had my hopes up but I called them and they can not do it on a 6.0 trans.
Looks like there is some limiting factor in the trans/6.0 combination.
If it is what I think, a code set when comparing input shat speed to tail shaft speed, I gad that problem with the BD Torq Lock system but worked around it. I am hpoing someone has tackled and solved the same problem.
If Toyota thinks they can fix a computer problem with a piece of shim stock we should be able to do this.
ghoff
Ca.
sorry man, I just looked at the year range and figured it might work for you. Good luck to ya.
HowieE
Princeton NJ
Ya at first glance that looked good. There seams to be some reason why they can't do it to a 5R1000 under forward load but can do it on decelleration against the exhaust brake.
I suspect it would set a code as the computer looks at both input and output shaft speeds. That was the problem with the BD Torq Loc when I put it on my 97 Sub. However I could use it in a manual mode and that is what I am hoping I can do here I just have to find one of the designers and talk with them.
