My new mud truck....
patrickc
Ontario, Canada
It's not a Power Stroke but it is big!! 96 F350, 351, auto, 38" ssr super swampers, 6" suspension lift, 3" body lift, plus another 7-8" due to the frame on frame. (soon to be removed) Soon to have 42" tires and cut away flares.
platinum01
Willis, TX
That thing is cool. Looks like a fun toy to play with. Bet you can't wait to get it out in the mud.
patrickc
Ontario, Canada
It is double framed at the moment. The lower is the original which all the drivetrain is connected too. The other frame is an F250 frame stripped it's front crossmembers and then bolted on the sides with large steel plates to the stock frame. All the body mounts are also bolted through both the frames and mounts.
Sitting on level ground it measures 43" to the bottom of the rockers and about 8' 4" to the top of the roof. It's a run and jump to get in and I'm 6'5"!!
kingkevindavid
Middleboro, Ma
thats a bad truck!, I don't think I have ever seen a truck lifted using another frame. What's it got for gears?
