ward cleaver
I'm trying to do the fuel tank breather upgrade. Does anybody know how to remove the "roll-over valve" on a '97? What can I replace it with to make the tank breath better/fill faster?
Bigger is better and will help allow the air to flow out easier when you are filling the tank especially with the large truck nozzles. Personally I would step the line up to 1/2" which would be easy to do and possibly with a single fitting, but if you already have 3/8" line then it'll work for you no problem.
