need serious help here..
Zookie400
I WANNA GO FAST
wallingford, CT
what scan tool are you using? i have a generic obd2 scanner that will pretend to read a powerstroke, but comes up with nothing every time.
the buzz test is a test that clicks each injector solenoid rapidly (makes a buzzing noise) so you can tell if one is dead or messed up. this only tells you if the electronics are working, so if they all buzz, there could still be a mechanically bad injector. not all scan tools can perform tests like that.
02stroker
Gratz, Pennsylvania
my uncle just had the same symptoms with his '02 7.3. Acted just like a cam sensor, no check engine light, and no codes. Dealer replaced the ICP sensor and the injection pressure regulator. Runs like a top now. ICP sensor was around $193 and the IPR was over $300.
drbalazo
Master
san diego, ca
ICP was replaced 2 months ago but the IPR could be the problem. If it is the IPR, hopefully its only the reseal kit.
