Question Oasis Question?
RJDiesel
Waterbury CT
:dunno I got a report on the warranty work that was done on my truck and I noticed this one below, it looks like the head were done but I am not sure? Any help would be appreciated.
DEALER: Harr Motor Company, Inc.
WARRANTY CLAIM NUMBER: 339379 ODOMETER: 097455M
PART NUMBER PART DESCRIPTION QUANTITY
LABOR OP
CONDITION CODE:
CONDITION DESC
3C3Z 6049DA CYLINDER HEAD 002 081103A 42 DOES NOT OPERATE PROPERLY
3C3Z 6A642AA COOLER CRANKCASE OI 001 081103B
3C3Z 6C683AA FLTER-ENG OIL 001 081103E
6C3Z 8A080B COOLANT O/FLO BOTTLE 001
F6DZ 8100A CAP ASY RADIATOR 001
3C3Z 9433BE GASKET SET-MANIFOLD 001
3C3Z 6731AA ELEMENT ASY OIL FILT 001
XO 15W40QSD 015
VC 7B 003
3C3Z 8575AA THERMOSTAT 001
3C3Z 9229AA GASKET CARB FUEL INL 008
6C3Z 9448A GSKT EXH MNFLD TO CY 002
W300013 004
W300051 004
W302193 002
3C3Z 9229AA GASKET CARB FUEL INL 001
W301386 002
W301390 002
W300006 002
W302725 001
8C3Z 6565B ROD PUSH 001
4C3Z 9E527BRM NOZZLE ASY-FUEL INJE 001
W301383 002
5C3Z 9F452AA TRANSDCR-EGR BACK PR 001
6051 GASKET CYL HEAD 000
97455 VERIFIED CONCERN OF CONSUMING COOLANT- COOLANT LEVEL WAS LOW AND NO EX TERNAL LEAKS COULD BE FOUND.PERFORMED TSB 08-11-3 FOR COOLANT LOSS.PERFORME D TEST ON CAP AND WAS LETTING GO AT 11 PSI,THEN TESTED THE DEGAS BOTTLE AND FOUND THAT IT WAS LEAKING FROM TOP,REPLACED DEGAS BOTTLE AND CAP.PERFORME D COOLENT PRESSURE TEST AND FOUND WAS LEAKING DOWN STILL,FAILED RADKIT
Yes, it looks like your head gaskets were replaced. The coolant leaking, internally, is the biggest clue. What I am wondering is why the Rod, Push (read "push-rod")? Was it bent? No clue given.
I just found an answer. If the heads were planed or surfaced, then a shorter push-rod maybe in order.
RJDiesel
Waterbury CT
Thanks DaveBen,;tu
I am not sure if that is a good thing or bad thing that they did a head job? I have heard some people mention to change the head bolts to studs or maybe it is the other way around? Would Ford do something like this under warranty? Thanks again
Ford only will replace their parts under warranty. You will have to buy the studs and then con them into installing them. They will do it, but probably not for free. The head bolts need to be changed anyway. They are a use only one time or Torque to Yield bolts.
jpringle83
WA
I know this is old but the dealers around here recommended installing them and only asked for us to pay the difference between them and the stock bolts. That way they never had to see us again. I wish all dealers had the fix it right mentality.
jpringle83
WA
Many here have had them done for free labor, for the bolts.
I guess I'm just lucky that all three dealers within a short radius of me would much rather put studs in at their labor cost minus the price difference of the bolts to studs. Only about $150 and the dealer even procures them. That being said I've never had it done because I've never had a head gasket issue but did lose my egr cooler once and now 7 of 8 injectors luckily all covered.
