Question oil in coolant
butch2000
michigan
Ok , so the coolant reservoir has oil in it ? but there is not any coolant in the engine oil ? how is that possible ?
snicklas
Super Moderator
Staff member
Greenfield, Indiana
Oil cooler is failing. Oil pressure is much higher that coolant pressure. You need to get that fixed ASAP. I would say there is a bit of coolant in the oil, just not enough to see. Because once you shut the truck off and the oil pressure relieves, the coolant pressure would be higher and could cause mixing. Unfortunately, sounds like time for an oil cooler replacement. I would have the EGR Cooler checked also, or, if you have no emission testing, have it deleted......
