Once again
swampthing32
Elberton ga
03 f350 superduty 6.0 runs a couple of minutes then shuts off . no codes . HPOP replaced last year , main fuel pump an filters 2 months back. Replaced oil filter and oil 700 miles ago. I was told that it's the FICM by another mechanic . help stranded in FL
There is a test you can do to determine if the FICM is going bad. You can google FICM Voltage test to see how to do this test. Not hard. You must have at least 45 volts for a good FICM.
jarrburg
