Reckon What This Would Weigh?
Got a customer that needs a quote on a 1983 AM General 6X4 Semi Truck.
They are not sure of the weight. They have been told 22k or 50k, I believe it would be closer to 22k. Oh, it doesn't run happy, happy, joy, joy. :rant
On the inside, passenger side of the cab.. there should be a data plate with ALL the shipping weights, hieght, length, cube and so on...... an much more.
22,000 pounds sounds right, but not 50,000 pounds. I had a dump truck (ten wheeler) that tared at 22,700.
I think you need to tell your drivers that this is going to be the new OTR truck.....:lmao
You will have to use a lowboy to haul this, won't you? Cost of getting it loaded and unloaded also.
Yes, or a roll back type trailer for heavy equipment that has a BIG winch on it.
When you have an INOP vehicle, I always figure in extra for that.
In this case, it would be alot extra.
SoCalPowerStroke
twentynine palms, ca
22k might be right but could be more check the inner doors to see what placard says, if all else fails get the model number and call a mil base and get ahold of motor t and ask them to pull up weights on it
Bama What about a tow bar?? The army base here moves them from base to base like that. Just thinking cost :sly:sly
SoCalPowerStroke
that would work if he had a rig set up for flat towing that much wieght with onboard air to be able to use the pulled trucks brakes if theyre still in decent operable condition(no bad holes or leaks in lines)
