Replacement Shocks
Steve Edwards
Southeast Michigan
I have 1 shock leaking on front left side, and was wondering what replacement to use.
Should I just replace with standard OEM shocks or something better.
Are KYB Gas A Just 554347 shocks good shocks. And are the front shocks easy to change while on ground?
KYBs will be better than stock shocks. Bilstein's are even better but they cost a lot. I am guessing you don't like spending money on your truck, so go with KYBs.
quazar
El Paso Texas
Bilsteins will make you happy, investing in good shocks is worth the extra bucks
ampb5rider
US
Take a look what's available, deside what you want to spend, see what the reviews are.
tabdiesel
Flower Mound, Texas
Here's the deal, I have Bilstein shocks on my F250. But,any shocks you put on a 3/4 or 1 ton truck won't make a noticeable difference because the spring rate is so stiff.
Go and buy the Bilstein's and be done with it. They should last the rest of your trucks life.
Bilsteins WILL make a difference on ANY truck you put them on. It may not be a big difference.
l2d racing
United States
I replaced the OEM shocks on my 8000 lb F350 about five years ago with KYB gas shocks. We use this truck to tow a 18,000 lb loaded race trailer throughout the southwest US exclusively. We have never had an issue and the ride is great with or without the trailer hooked up.
castellscl
