Reverse Lights (additional)
i-Henry
Yakima, WA
I want to wire in additional reverse lights. I'm going to take the power from trailer wiring. That's the easy part. My question is, how would I wire in an override switch in the cab so I could turn them on, say if I was parked and just working on the trailer behind the truck?
To turn mine on I just set the parking brake, put the transfer-case in neutral and put the transmission in reverse. You don't list your truck as being 4wd so this may not work.
castellscl
