SilverStar Headlight Bulbs
CPSS
Clifton Park, NY
The Silverstars do actually produce more light compared to stock.
Heres a test I did and reported on last year:
STOCK BULBS truck running inside shop
Battery voltage 14.39
Voltage at lamp socket 12.68
Current 1 low beam 4.5A
Light brightness at 10ft 2830 LUX
Rewired lamp thru 30A relay, fused, and 12G wire directly to battery
Voltage at lamp socket 14.28
Current 4.5A
Light brightness at 10ft 3770 LUX
Next we tried SYLVANIA 9007ST Silver Star lamps
Stock wiring setup
Battery voltage 14.38
Voltage at lamp socket 12.69
Current 5.0A
Light brightness at 10ft 3100 LUX
Rewired lamp thru 30A relay,fused,and 12G wire directly to battery
Voltage at lamp socket 14.30
Current 5.0A
Light brightness at 10ft 4580 LUX
So I think you all can see, the higher output of the Silverstar replacement lamps (or any other lamp upgrade for that matter) will really not be noticed untill you improve the wiring. There is a voltage drop on the stock wiring of almost 2 volts at the lamp socket. Any of the aftermarket relay/harness kits would work, or you can make your own for under $10.00.
Great test.. Looks like I need to upgrade my harness before next fall. We are down to about 2 hours of dark and before long it will be light 24/7 but the extra 1480 LUX would be handy next winter:)
I as doing a little research on just what relays and fuse holders I wanted to use when I found a KYO Plug-N-Play Heavy Duty Wire Harness Upgrade Kit (Model 9007)for only $19.95 on ebay. I imagine a guy could get all the parts for less than $20 but time is money so I thought I would give it a try. I will report back when I get it and let you all know if it is a cheapo or a good product..
CPSS
Clifton Park, NY
Headlight Harness This is a real heavy duty harness designed specifically for out trucks. Be carefull of the cheap stuff on E-Bay. You don't want your headlights crapping out hundreds of miles from home. :eek:
Both of them have 40amp relays but we will see about the rest of it when it gets here. For $20 I thought it was worth a look and I will at least end up with the needed plugs and relays without running all over town to find them. If the wiring doesn't look heavy enough I will redo it. The one at Black Cloud is $49 and for that it would be worth driving around town rounding up all the parts for much less.
