Humor Slow shifter
copracr
Brunswick,OH
OK, so my buddy has a 04ish 4x4 duramax 2500 with tons of upgrades- intake, exhaust stacks, programmed, 6000 dollar auto transmission, much more i'm sure.
I'm not impressed though. its damn fast, but my seat-o-the-pants-ometer says I'm pulling harder in 3rd gear. I've got basic CAI, 4" exhaust, and a 5 position chip which i leave in the 50hp setting. My problem is this stick tranny couldn't shift through the gears fast enough to beat up an escort. If I try anything remotely resembling a quik shift on 2-3 I get grindage at best, nothing but free revving usually.
I have about 200k on it so if I got the tranny rebuilt would I see a big improvement? Or is that just the way it is? Do i need some kind of quik shifter like the do in the mustangs?
If it's got 200+ on it, you need to be nice to it. It's been good to you for a long time now and the ole gal is still hanging in there.LOL
I don't know enough about a stick to tell you, but I bet someone will be here before long that knows them well.
OK, My problem is this stick tranny couldn't shift through the gears fast enough to beat up an escort. If I try anything remotely resembling a quik shift on 2-3 I get grindage at best, nothing but free revving usually. Do i need some kind of quik shifter like the do in the mustangs?
I use Red-Line, Full Syn ATF in my 6 speed. Makes for MUCH smoother shifting. From habit, I often slip shift (no clutch) between 4th, 5th and 6th, towing the 5r.. the full Syn basically eliminates the Notchy, "gota git it just right".. shifting.
A bit pricey but well worth the money, IMO. :dunno
f100cleveland
When In Doubt,THROTTLE ON
Southern Minnesota
You just have to much mass inside the tranny spinning at different speeds during a speed shift to make it happen as fast as like say a mustang. I think you can get a short throw shifter for one. That may help too. If you still have the stock clutch in it any more than the 50hp tune will make it slip during a hard shift. I put a south bend clutch in the 01 I had and that helped the shifting some too. Try to get you D-max buddy to do a 45-60mph rolling start against you. The old 7.3 did pull strong there.
I am with these guys on not being able to make a truck tranny speed shift. You can smooth out the shifts, but there is too much mass for speed shifting.
copracr
Brunswick,OH
I'll give that Red-Line, Full Syn ATF a try. I guess I'm not looking for mustang slam through the gears shifting, but big joe called it- I have to get it just right or there's grindage/nothing. It's really picky.
My 7.3 would shift hard when the clutch was needing replacement. It didn't slip or anything like it. Much better when I got it replaced.
:):D I didn't mean to say a Synthetic ATF would allow "Speed Shifting". I totally agree.. these 6 speeds aren't designed or built for that.. but it does, IMO, make a noticable difference in the ease of shifting gears. Simple, Palm of the Hand stuff.. Less having to find that certian.. Notch.
I mainly use the Red-Line Syn. lubes, only cuz I've used them for years, in all kinds of gear boxes & difs, long term.. and never had a failure.
Other Synthetics may be equaly as good ?
hawkdriver
Lake Martin Alabama
I'm due for a clutch change and I'm going to swap to Redline when I do. Hopefully it will help some. I don't have any issues when driving normally but you aren't going to win any races off a dead stop for sure. Like f100 said, take him on rolling down the road. Mine will leave people in a cloud of smoke as we roll up a hill. Really surprises them.
