AKmud
I have a 2000 F350 7.3 Superduty mated with a 6sp manual tranny. I have been experiencing some starting problems in the last couple of weeks (since the weather has been cooler). The truck idles rough and puts out a fair amount of white smoke on startup that smells heavily of raw fuel, but clears up after 20-30 seconds or so.
Two days ago, I went to start it and it wouldn't fire. It turned over nice and fast, but no fire. A little troubleshooting and I found a small 20A fuse under the hood that was blown. I changed it and it started like normal. I don't have an owners manual so I'm not sure what the fuse controls but I am guessing a fuel pump relay or something. It has been started several times since then and no problems other than the normal cold smoke I mentioned.
This morning (temp around 25*F) it wouldn't start again. I checked the fuse block and no blown fuses. I wiggled things around and then it started just fine. I had the hood open when it started this time and when I got back out to shut the hood, I noticed the white smoke was coming up through the engine compartment quite heavily. I couldn't tell where it was coming from, but it obviously wasn't from the end of the exhaust pipe.
My question is.....is the smelly smoke anything to worry about or is it normal for colder weather and why would it be coming up through the engine compartment?? Turbo problems? My coolant level hasn't changed so I don't think it is a water problem. The only thing I have changed is running 2-stroke oil now. This is the first tank I have tried the 2-stroke in.
I'm not very familiar with the PSD (this is my first), my last was a Cummins.
Any ideas?
Any ideas?
