Starting problem
fisteck
Have service engine light on, code p0340 on a 2011 f250 6.7l. Also has a long crank. Sometimes have to
cycle key more the once before it will start. Has a new cam sensor.
Are your batteries charged up? Will not start if battery voltage drops below 10.5 vdc. Could be a bad CPS which you have replaced (bad from supplier). Good luck!
fisteck
I will have to look at batteries and starter.
79jasper
El Paso, TX
If you still have the p0340 after clearing and it came back, that's where you should look.
Sent from my SM-G892A using Tapatalk
