Time for a clutch install party
You buy the plane ticket and I will buy the pizza and beer.
Picked up a South Bend Dual Disc FDD32505 :sweet
Next stop will be the injector shop......
You buy the plane ticket and I will buy the pizza and Cokes,
and I will be there.
dpantazis
#12
under the cheddar curtain
i dunno, i think you should kick in a couple of guided fishing excursions and you might have a posse!
but that sux you have to do a clutch job! i hope it goes quick and easy. you think you need all that umph with that clutch?
RoyBoy
Diesel Dork
central WI
The South Bend dual disc is a very nice unit, worth the $$$ IMO. Have fun :D
So when are you stopping by? I do think that 4500 miles is a bit far to drive to change your clutch but it is nice and sunny with a touch of smoke in the air.
You think you need all that umph with that clutch?
More clutch than I need but I got a good deal on it from craiglist. Lists for $1800. I got the clutch, 45 gallon transfer flow aft replacement fuel tank, banks intercooler and a set of centerline 17x9 wheels for $800.
How is the pedal pressure? Do they engage smooth?
I have never did any research on the dual disk so I don't know much about them. Just kinda ended up with it.
94f450sd
certified nutjob
plymouth,ma
good deal!:sweet easy job.i could do a few of these a day and be happy.as long as the bell bolts arent siezed in the bell housing its a breeze.recomend coating the bell bolts with never sieze :sweet
RoyBoy
Diesel Dork
central WI
Pedal Pressure is about the same. The things I notice are a slightly harder shift into low or reverse, and sometimes a little hopping when I try to back up slow. Nothing real major though.
Big noticeable advantage is that I can go out on the pavement, rev and dump the clutch. Tires break right loose :D never used to do that :lmao
