tranny problem
jetallman
Hannibal missouri
changed tranny filters and fluid last night in my 05 F250, manual called for 16.7qts filter box for 15.7, looked like about 10 came out, I put 16 back in and this morning had fluid running out the top of tranny, cant really tell level on the crappy dipstick they have, did I put to much or something else go wrong
trackspeeder
Stone Crusher
North Branford CT
Fluid coming out of the vent means it has been over filled.
Lay the dip stick on a piece of paper. That will help you read it. ;tu
If 10 came out and you added 16 back in, if is OVER FILLED. Drain off about 6 quarts and then check the dip stick after running the truck.
Hansel
Georgia
What he said, I've done that before. I added too much back into the transmission and the next morning I had fluid all over the driveway. Just drain some out and then recheck your fluid level.
