trans. info update
Dogman
tampa,FL
Found out today that Mercon SP is now not the only trans. fluid for the 6.0 trans., you can now use Mercon LV and or mix the two. Mercon LV is a lot cheeper then the Mercon SP.
There is a ford service note on this change.
Ford Special Service Message 21114
"MESSAGE TITLE: REPLACEMENT TRANSMISSION FLUID FOR SERVICING TORQSHIFT TRANSMISSIONS
APPLICABLE VEHICLES :
2003 - 2005 TRUCK : 00126 EXCURSION
2003 - 2008 TRUCK : 00028 F-SERIES
2004 - 2008 TRUCK : 00016 E-SERIES
2006 - 2008 TRUCK : 00175 F-SERIES MOTORHOME
2006 - 2008 HEAVY TRUCK : 00168 LOW CAB FORWARD
OASIS MESSAGE :
ALL 2003-2008 F-SUPER DUTY, 2003-2005 EXCURSION, 2004-2008 E-SERIES AND
2006-2008 LCF VEHICLES EQUIPPED WITH A TORQSHIFT AUTOMATIC TRANSMISSIONS SHOULD
BE SERVICED WITH MERCON LV AUTOMATIC TRANSMISSION FLUID IN PLACE OF MERCON SP.
THIS INCLUDES TOP OFF AS WELL AS FLUID REPLACEMENT. MIXING MERCON LV AND MERCON
SP IN THE TORQSHIFT TRANSMISSION IS ACCEPTABLE. USE MERCON LV TRANSMISSION FLUID
TO SERVICE VEHICLES EQUIPPED WITH TORQSHIFT TRANSMISSIONS. WHEN ADDING OR
REPLACING TRANSMISSION FLUID IN A VEHICLE EQUIPPED WITH A TORQSHIFT
TRANSMISSION, USE MERCON LV TRANSMISSION FLUID.
Thanks for the post, I am sure it will help some of our bunch. http://www.schaefferoil.com/ This is the only TRANSMISSION FLUID, I have ever put in my truck, it's for sure not
cheap but it's worked great for 111,000 miles now and that pulling my Fifth-wheel a lot. I change it about every 35,000 and it looks about like it did when I put it in new.
