Undercoating Removal
Big Bald Guy
San Diego,Ca
previous owner was a bone head and coated entire bed with undercoating. anyone have a easy way to get it off. paint thiner works but is slow
Smoky
Mississippi State
Hey Big Bald Guy, how old is your truck? If it is real old you may be just as well to find a replacement bed. Post up some pictures of it. BTW, welcome to Superduty Diesel.
Smoky
Mississippi State
Surely you mean he just coasted the inside of the bed with undercoating????????? Try some ACETONE to see if it will work any better. The undercoating should be more pliable than what the Line X is so you may be able to scrape some of it off with a plastic spatula or try a razor paint scraper. You will remove some of the paint but cleaning it all down and reprime before putting the Line X on. You may not need the primer but ask Line X if it needs to be primed.
BBG, Welcome to SSD.com, Yes there are a lot of Bone Heads still out there.
I've actually had pretty good experiences with a wire wheel on a grinder. you're likely to get it a bit too far in some places and need to touchup the base primer but otherwise that will leave a great base for the linex to adhere to
rukirok
