Upfitter Switches in an X
X-Hibition
Idaho
I've seen the pictures of them in the pick-ups, but I would like to know if the Upfitter Switches fit in our dashes.
I've got an '05 X with a little cubby hole beside the switch for my adjustable pedals, and as I add accessories I thought the upfitters might be a nice central location.
Anyone do it, does it work, can it be done?
Northeast Texas
i dont think the ecm is set up for it, need t do some digging at the ford fleet site in upfitters
this is one option the x folks dont get over us pickups :sweet
by the read below you are not IT.
SEIC strategy
– Provides elevated engine speed to drive auxiliary
commercial equipment such as hydraulic pumps,
generators, air compressors; or maintain vehicle
battery charge under extreme electrical
demands.
– Standard in all PCM's for Super Duty F-Series
light truck, and E-Series, over-8500 lb. GVWR,
all powertrains.
– Replaces the Auxiliary Powertrain Control
Module (APCM) used with 2004 model year and
prior diesel engines.
• Blunt-cut wires to access SEIC, and customer
access for VSO, CTO, PARK, PARK-NEUTRAL
signals
– F-Series: Located in the cabin, tagged and
bundled above the parking brake assembly.
Pass-thru wires are in the same bundle.
– E-Series: In the engine compartment, tagged
and bundled with the large harness running
below the windshield/cowl. Remove some of the
plastic harness tape where the harness exits its
plastic support gutter above the engine air
induction tube to reveal the blunt-cut wires.
hey robert, an X owner could maybe make their own switches to run whatever like want, like i did in this pic. alittle more work, but could be done and would look just as nice.
my switches
or they could PM bushpilot, he has some nice lookin switches he got out of a place in alaska, he PM'd me the info today, i would be glad to pass along to X-hibition.
bushpilot's switches
bushpilot's look alot like the upfitter switches to me.
good luck x-hibition:thumbs
Northeast Texas
yes an x owner could make his own switches, i was only commenting on the upfitter switches (as an assembly, like the 05 06 trucks)as he, i thought was directing,
as a thrifty person i would agree to gen up some switches like you and i have even done in the past.
:sweet
yes bush pilots....... are very nice looking,
man i THOUGHT i felt my ears burnin' ;)
Ive seen the carling switches (that i have) mounted
in the over head (garage door opener & sun glass holder).
I wanted mine 1) hidden and 2) in a bit of plastic that i could
EASILY (and inexpensively) replace.
I considered carling "marine" switches...thinking they were more
readily available...but MAN they were like 35bucks (and UP)
per SWITCH.
if anyone has any questions about Shane & his ablity to
deliver in a TIMELY manner feel free to contact me & confirm
it w/ shane...hes a great guy, honest (doesnt gouge on shipping)
and delivers quickly.
You can view the actuators, brackets, switches, and tool at:
http://community.webshots.com/album/114685432SwLxOb
You can also view some install pictures at: http://community.webshots.com/album/115793651CUFFq
Shane (a fellow diesel nut) can be contacted via:
Shane Linse <[email protected]>
let 'em know bushpilot (aka: don rumsey) from superdutydiesel.com sent ya
(i get zero from this...i just want shane to know that his good business
practices are being rewarded) !
X-Hibition
Idaho
The reason I thought I could do this was that I thought I had the engine compartment provisions for the Upfitter Switch. I have the short unattached wires up near the firewall on the driver's side just like in the pictures I've seen so factory switches...maybe? Do the switches fit in the cubby hole?
I know I can go aftermarket, I just like using OEM (even if from a different year) just for that look.
Thanks for the help.
X-Hi no problem id do the same, if i could.
Worst case youve got a option w/ what i sent too.
OEM does look nice. i try to go that way too, when ever possible.
Matt M PA
SE PA
The unused wires under the hood are not for the upfitter switches...they are simply for convenience when hooking up accessories.
The factory upfitter switches will not mount to our dashes as the 2005 SDs use a different dash. The 2005 Exs use the 2004 SD dash. As others wrote, you could add them, but you would be most likely hooking up the "factory" upfiter switches like and aftermarket switch anyhow.
I got a pair of LED lit roacker switches and mounted them in the dash next to the lighter. There is a blank spot there. I also cahnged the resistors in the LEDs ae it was too bright at night. There are pics in my gallery.
X-Hibition
Idaho
If I can't use the Upfitters, the convenience wires under the hood...where is the other end for them? Fused or not? What is the story on them?
castellscl
