Who else would do a good job changing my ATF?
dsonyay
Slidell, LA
I have the 6.4 with auto tranny. The dealership wants a little over 200 dollars to do a tranny flush. Would an independent shop or tranny shop do just as good a job for less? Is there anything special about the tranny that makes it important to only have done at Ford?
dsonyay
Slidell, LA
My dealer quoted me about 175 for a fluid replacement and 25.00 more to do a "flush"
Not too bad.
rock_doctor
Member
hello, PJ
You can change it yourself or have your favorite mechanic do it. You will have to supply the oil and filters. Last year we changed the atf in the excursion. Just gave the mech a case of sp and the two filters (Only used 8qts). If you have a 4x4 you should also change the atf in the transfer case (2.5qts) at the same time. Change both every 30k with out fail... You can use anything from SP to mobil 1 in the transfer case but only SP in the trans.
