Question who has AE?
atk
Moderator
simcoe, ontario, canada
recently purchased Auto Enginuity and was under the impression you could do a CCT(CYLINDER CONTRBUTION TEST) on 6.0L trucks. i can do a power balance test, but no CCT test....
any thoughts....thanks
atk
Moderator
figured it out...right click on options and choose actuation. will come at bottom part of screen and then you can disable 1 injector at a time.
depending if you have newer version of AE, it might not be avaiable on older version. should beable to update software....
djanzen
Saskatoon/Saskatchewan
The balance test is the same as the cct. the other test is a cylinder cutout test.
these are both useful test when a injector problem is suspected.
RoyBoy
Diesel Dork
central WI
You need the newer "ProLine" connector to do the "Power Balance" test. You can send your older one back for an updated connector for a fee. :sweet
