exhaust brake
keith jolley
Adin,ca.
I have a 2016 6.7. the exhaust brake seems almost non existant.My dealer says there is nothing they can do that's just the way it is set.Does anyone know if they can get more aggresive through the computer?
01yellerCobra
Cali
How are you using it? I've found it best to have the engine around 2500rpm when I use it. I usually put the trans in manual and lock it at a lower gear. I can stay at 65 while towing my car down a 6% grade without touching the brakes. Sometimes I have to turn it off because it keeps slowing me down.
keith jolley
Adin,ca.
I use it towing my 5th wheel.My Dodge would slow you down immediatly.It also had the cackling sound.
The Ford has no noticeable sound or feel.Ihave disc brakes on the 5th wheel,so I have plenty of stopping power.I am just dissapointed in the Ford brake.
01yellerCobra
Cali
Maybe try downshifting manually when you use it. I've found if the RPM is too low it doesn't work as well.
Did your Dodge have the DPF? That thing muffles a lot of noise.
79jasper
El Paso, TX
I'm sure tuning can be done to make it better.
FiveOfastback
Bethlehem, Pa
Does truck have tuner installed now?
All tuner and tunes I know of only have exhaust brake on stock or tow tune. I have a del;6;3: 2016 with tyrant tunes and only get exhaust brake on Tow Tune.
dburress
Lakeland, FL
If you don't have much of a load, you will not notice it. I used it up in the mountains with a 36' gooseneck trailer and it never ran away from me. It just doesn't sound like a big rig.
RSG
Savoy IL
I use it even as an unloaded daily driver. I absolutely feel a difference in stopping.
01yellerCobra
Cali
I showed my wife and son how to use going through the mountains in Oregon. They both got a kick out of it.
