High Idle
dieseldork
dieseldork
ca
Its been a while since I have been on the sight, But I have a question for the GURUS..... When its cold out and the truck idles for a while, the idle kicksup on the truck?........ when I jump back in and tap the brakes it will return to a normal idle ..... What gives?... Is this normal and what is the reason?
It will also kick back on if I continue to let her idle. It only does it when its in the 30s, or lower.
fgtex
Little Elm, TX
It is normal for these trucks to do. It is a built in high idle to help the engine warm up when it air temp is cold.
dieseldork
dieseldork
ca
Thanks FGTEX, I havent had the truck through a winter yet so This was a new one for me....
fgtex
Little Elm, TX
The EBPV closes to help the vehicle warm up also. Go stand by the exhaust while it is on high idle and the EBPV closed...it sounds pretty cool.
Im not sure i agree w/ the "warming" device...its more of a wet stacking
issue i think.
My experiance is that no matter HOW warm the truck, if the out side
air is below some temp. (40* or so...) the idle will kick up automatically...
and it doesnt matter if you just started the truck or youve stopped
and are "idling" (having just run the truck).
so i tont thing kits a "warmth" (of the engine) issue...its more of
an outside air temp issue
