02 just idles
aaklingler
Winfield, PA
My buddy has an 02 and all it will do is idle, it won't pick up rpms at all and all the gauges are dead, whats wrong?
Allen
Dogman
tampa,FL
sound like the gas petal is shot. Dorman sell one but it's the none moveable one for about 35 bucks. part #699-205
RSG
Savoy IL
possibly the go-pedal..
not much else short of wacky wiring is gonna cause it...
RSG
Savoy IL
Yes...if you follow the link in my earlier post, it explains that fuse 45 was blown (that's why the gauges were also out)...and I found a chafed cable in the steering column going to the overdrive switch. 3 wires in a cable, 1 bsted.
aaklingler
Winfield, PA
Where abouts in the steering column was the bad wire, his fuse 45 is blown? Will they normally blow that fuse when the pedal goes?
