03 7.3 loses all electrical power
trickyricky23r
berryville, va
four times now it has lost all battery power while going down the road. the first three times were momentary but was enough that i had to reset the radio. this last time it was in a bad spot on a busy highway and it was dead for about 10 minutes. no power at all, didn't even have hazards. i've asked a few local diesel guys and they are stumped, please help
It sounds like a loose ground connection. Check ALL of your connections to the batteries and the starting solenoid. Check that they are CLEAN and tight.
bcvickers
Minnesota
Did you solve this yet? I can almost guarantee it's the large power connection behind the battery on the drivers side inner fenderwell.
trickyricky23r
berryville, va
no i haven't solved it yet but i did figure out it mostly happens on hard bumps, potholes, etc. i'll check that out tomorrow after work. thank you!
rmwitt
Seattle/WA
definitely, check your grounding cables: one on each side of the block. Hard to get to, but they will make a difference. Also, consider adding or checking additional grounds per the attached. The attached also includes testing parameters and instructions for a volt meter.
trickyricky23r
berryville, va
thank for the help and suggestions. it ended up being a breaking/broken wiring harness on the right side fenderwell. i've driven it a couple weeks with no problems
