'04 sub-woofer cabinet?
unfortunately that wont be much help...and it wont
leave you many choices
beginning w/ the 2004 model year the rear seat
set up changed...they added an under seat tray system
and seat bottom AND backs that folded...this change
reduced the behind the seat "space".
at the bottom (deepest) part of the seat theres less than
7inches & at the top (shallow) part theres less than 4 inches.
w/ the exception of some of the NEWER shallow mount
speakers (pioneer, jlaudio, kicker etc) its a difficult (read: CUSTOM)
box...and even that will depend on the size speaker (depth) you
use.
most of the PRE-FAB boxes you have will be for the 99-03 and even THOSE
may not be specific enough to fit the speaker you decide to use.
my recommendation...measure the depth behind the seat, include / calculate
the thickness of the board youre gonna use (to build the box) either
1/2in or 3/4in and then build your own box
irish4x4
Mayor of Margaritaville
Reno, Nevada
The box is the easy part. I had a hell of a time finding subs that were thin enough to fit in the box. Ended up getting the Sony xplod 10's just because they fit AND they were in my budget.
rustinh1
Kansas City
Try Audio Enhancers. They have a box for 2 shallow mount 10s that goes behind the seat. That's what I was running in my 06 and I tried to put in my 08. Unfortunately, with the new shoulder belt in the middle, this box won't work in my 08.
Heck, if you want one, I'll sell it cheap!
kenholl
Its my side of the garage
McKinney, TX
Good copy! Thanks for all the input guys. I'll post back here when I start to make some progress on this
georgetown texas
Most shops will build you a custom box out of wood and fiberglass for under 300 bucks. With the fiberglass they make the center deeper for the bottom of the speaker without having to make the box thicker.
woofer700
Diesel is cool
S/D
two Rockford P2 10s will fit, along with a Kicker 700.5 behind the seat of a 06 crew cab, box is total custom, but should work for ya.
Did some checking, the new 80-09 rockford p2 subs will no longer fit, for the new year they made them deeper. the older version 07-08 will fit, i believe they are 5 3/4" deep, sorry for the confusion boys.
