05-07 headlights????
bigblack250
Branford, fl
can anyone tell me if the 05-07 lights fit in the 99-04 core support/header panel??? has anyone done this? is there a write up anywhere about it? i just got my new lights in and they dont really look like theyre gunna fit:confused:
No they won't with out rebuilding the core support. It can be done, but it is not a bolt in project.
wpfd571
White Pigeon Mi.
Yep it will work..... Take your old lights off and get ya a grinder you have to cut most of the plastic out from behind the old lights so make sure you want the new lights cause there's no going back after you start cutting. I took my bumper off to make it easier to put the lights on. Just the 2 screws on the bottom of the lights then 2 on top. I used some of those push in clips like you use on door panels to secure the top in and it works great. You also have to splice into your old lights cause they use different bulbs i found an old western snow plow light adapter in the shop so mine was a plug and play deal.
My avatar is my 03 with the 05+ harley lights
jarrburg
