06 F350 noise after shut down
jon dietrich
Inver Grove Heights, Minnesota
Every time I shut the motor off it sounds like a relay of some sort stays on for about 15 to 20 seconds. I pulled the glow plug relay off as it was making the noise and it didn't shut off. Does anybody know where to start? Thank you
RoyBoy
Diesel Dork
central WI
Is it a buzzing type noise from under the hood? If you have a older PCM flash, it's normal cycling the injectors to limit rough cold starts.
