Help Needed 2001 e-350 dually 7.3 lt how do I know which rear my rig has ?
bamyhre
Frenchtown N.J.
Driver side rotor shot , need to know axel to order rotor .Truck is e-350 super duty with auto trans dually . vin #1fdse35fx1hbo3014
There's a Axle code on the Driver side door jam data sticker.. yer owners manual will show you the ratio.. or call a Ford dealer.. and there should be a metal tag on one of the Rear Diff cover bolts.
OBTW.. WELCOME to SDD ;tu;tu
Deerjager
Meister Gewehr
Forest City, NC
X2 on welcome to forum. Try to do an internet search as well on your code.:)
The axle codes are shown in the WIKI Section, on the TOP BLUE LINE above. Just click on Articles and look for it.
Dave :)
Guys, the TIKI WIKI only lists axle ratios for the different axles based on door code not the axle type
your rear axle should be a Dana 80 unless it's been swapped out
When looking for a rotor you should only need to know 1) Dually or SRW 2) location of parking brake (driveline or in the rotor hat)
