2002 f350 front vibration
excavatorman6
rockford mi
Hello i need some help.I'll start with what i have done.upper/lower ball joints,steering linkages,rebuilt front drive shaft and balanced,had to put a new ring gear,pinion gear,pinion bearings and seals,new bearings in both axle shafts,new tires,so you can see my frustrations.I have manual lock outs on this.Any help
Have you checked to U-joints in the axles?? If they are shot. the axles will not operate smoothly.
dserge66
