2007 f250 6.0 died while driving
puma
Truckee Ca.96161 USA
This truck has 70k miles and it just died while driving. No DTC codes. Truck cranks ok but no start
1st...this is a guess, assuming batteries are charged and
the fuel pump is running (and your fuel filters are clean & the
HFCM has been drained of water)...
your model year is indicative of a problem w/ the HPOP
connector <leak down> (2005-2007 trucks were affected)
your dealer should check the HPOP pressure as supplied
by the ICP .
the MINIMUM required pressure developed by the HPOP
required (to start the truck) is 500 psi and thing less is,
less then 500psi and the truck will crank w/out starting.
SOMETIMES if its a "slow" leak...you can CRANK it long
enough to build the pressure enough to start...but your
problem will eventually need attn. & repair.
there is a TSB on the HPOP connector...
FORD Dr. HPOP Connector Bracket TSB
there are improvements on the TSB connector...you might
want to seek this part out for yourself (international truck
dealers should have 'em)...and INTERNATIONAL part numbers
are listed in this document --> FDDTS - New One-Piece High Pressure Oil Connector
mwalls54
Tex
Somewhere in Virginia
have you checked the fuel reset on the passenger kick panel under the dash? check fuses. about 8 months ago my truck blew the interior fuse box. Dont know how or was it explained why.
It did have a HPOP installed under warrenty @ 48k Is it possible that it is a goner also?
depends on what they did, was it just a pump replacement w/ the same
problem bracket ?
it wont take long to eliminate the hpop...w/ the proper diagnostic software.
F350DRW1
Waylon Fan
N.J.
Yes. My brothers truck went thru 2 fittings in as many years. Luckily under warrantee.
does the "Wait" light come one when the key is turned to the run position?
