2007 grease fittings
Get this- The E series had plugs in the ball joints and tie rods where a grease fitting would be. I took out the plugs and put in grease zerks. Maybe the F series is the same way. If you see a very small plug on the flat spot of a ball joint or tie rod end, it should be re-moveable for a zerk.
if only....
