2010 flasher for LED lights
GCJB2002
delta bc canada
I have a 2010 f350 and i put led bulbs in and now the turn flasher is in turbo mode,do I need to put in a stronger flasher in.And if so were is it located.
Thanks Geoff
`08 Blue Crew
Somewhere in the lower 48
My understanding is that there is no stand alone flasher in our trucks. There is some sort monitoring by the computer and if it senses there is not enough power consumption (ie burnt bulb/open filament) it will put the blinker into fast mode. I looked into a bit more, but never went on with the project.
One cure is to add a load resister for each LED bulb. An example is shown here: LED Brake Light, Turn Light and Tail Light Bulbs - Super Bright LEDs which will simulate a filament being present.
Veece
Moorhead, MN
Just picked up a LED 5 pin flasher from the Parts store, which he looked up...so I'll be looking for that relay near the passenger fuse box, or some were. Saved the $10 recipt just incase!
NJKen
Is a proud new daddy
central NJ
Im curious if the flasher worked. If it did, Where did you get it and whats the part number?
Ken
