Fire Rooster said:
My question is how many people in the triple digit climates are using one? I live in Phx and it was a nice 117 degrees outside yesterday. I tow a 35ft 5er a lot and do not want to overheat my truck. I have seen it it get hot once when towing and that is what scares me.
It's only 8 deg F hotter before the thermostat opens...that means that at operating temperature (where the thermostat opens) it waits another 8 deg. Once the thermostat is wide open be it a 195 F or a 203 F it's the same.
If the truck is going to over heat with a 195 stat it'll over heat with a 203 stat. The thermostat simply controls the normal operating temperature.
The condition of the cooling system determines if it will over heat or not. Many things come into play here, from the condition of the clutch/fan and where it kicks in and how well it holds/flows air when engaged, to the condition of the radiator and the coolant i.e.percentage of antifreeze.
